ASuba
7 years agochanging endian in Avalon FIFO Memory
Hello I am using Avalon FIFO memory with inout to AVALONMM_Memory mapped interface and Output conencted to AVALONST_Source. I find that the 32 bit days entering Memory mapped input is reversed bytew...
GuaBin_N_Intel
Contributor
7 years agoThis is because by default, avalon FIFO's streaming interface has the properties "firstSymbolInHighOrderBits" set to be true. You can check it in Qsys>System contents by clicking on the streaming output. When it is true, data[31:24] will become D0 in data streaming https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/mnl_avalon_spec.pdf, Table 18. You could not change it as it is predefined setting in the IP. What you can do is to reverse the data symbol at output of Avalon-mm FIFO.
