SScib1
7 years agoCannot read Vendor ID of ARRIA 10 PCIe Root Port AVMM IP on CRA bus
The PCIe RP Ip is in LO state, Sync is ok. My first acces is to read the Vendor ID of the PCie RP IP. When I sent the following sequence on the CRA bus I never get an answer: Add=2000h Data=0400_...
SengKok_L_Intel
7 years agoHi Serge,
Are you trying to read the vendor ID of the end points that connected to the root port? From the CRA sequence above, both request ID and BDF = 0? Could you please confirm if the BDF is all zero?
Regards -SK
