Stephanie
6 years agoCannot Read data from MAX10 UFM
I am unable to read data from a MAX 10 UFM IP. I'm using the On-Chip Flash Intel FPGA IP, trying read only memory for sector 1, and initializing the data with 125 values with both the .mif file for ...
YuanLi_S_Intel
5 years agoHi,
From the warning message, seems like the connection is not completed. It would be better if you could connect the IP and your testbench properly as per the user guide.
Thank You.
