Cannot Read data from MAX10 UFM
I believe I am following the User Guide. avmm_burstcount is set at the same time avmm_read is asserted, I'll attach a waveform.
Is there any more feedback for this issue?
- Stephanie5 years ago
I also get the following warning messages throughout the simulation:
# ** Warning: (vsim-2685) [TFMPC] - Too few port connections for 'the_master_to_user_fifo'. Expected 13, found 8.
# Time: 0 ps Iteration: 0 Instance: /testbench/UUT/master/the_master_to_user_fifo File: C:/MAX10_work/burst_read_master.v Line: 237
# ** Warning: (vsim-3722) C:/MAX10_work/burst_read_master.v(237): [TFMPC] - Missing connection for port 'sclr'.
# ** Warning: (vsim-3722) C:/MAX10_work/burst_read_master.v(237): [TFMPC] - Missing connection for port 'eccstatus'.
# ** Warning: (vsim-3722) C:/MAX10_work/burst_read_master.v(237): [TFMPC] - Missing connection for port 'full'.
# ** Warning: (vsim-3722) C:/MAX10_work/burst_read_master.v(237): [TFMPC] - Missing connection for port 'almost_full'.
# ** Warning: (vsim-3722) C:/MAX10_work/burst_read_master.v(237): [TFMPC] - Missing connection for port 'almost_empty'.
# ** Warning: (vsim-2685) [TFMPC] - Too few port connections for 'flash'. Expected 15, found 10.
# Time: 0 ps Iteration: 0 Instance: /testbench/UUT/flash File: C:/MAX10_work/MAX10_work.v Line: 148
# ** Warning: (vsim-3015) [PCDPC] - Port size (17) does not match connection size (32) for port 'avmm_data_addr'. The port definition is at: C:/MAX10_work/max10_flash/simulation/max10_flash.v(13).
# ** Warning: (vsim-3722) C:/MAX10_work/MAX10_work.v(148): [TFMPC] - Missing connection for port 'avmm_csr_addr'.
# ** Warning: (vsim-3722) C:/MAX10_work/MAX10_work.v(148): [TFMPC] - Missing connection for port 'avmm_csr_read'.
# ** Warning: (vsim-3722) C:/MAX10_work/MAX10_work.v(148): [TFMPC] - Missing connection for port 'avmm_csr_writedata'.
# ** Warning: (vsim-3722) C:/MAX10_work/MAX10_work.v(148): [TFMPC] - Missing connection for port 'avmm_csr_readdata'.
# ** Warning: (vsim-3722) C:/MAX10_work/MAX10_work.v(148): [TFMPC] - Missing connection for port 'avmm_data_writedata'.
# ** Warning: (vsim-2685) [TFMPC] - Too few port connections for 'ufm_data_shiftreg'. Expected 11, found 6.
# Time: 0 ps Iteration: 0 Instance: /testbench/UUT/flash/onchip_flash_0/avmm_data_controller/genblk6/ufm_data_shiftreg File: C:/MAX10_work/max10_flash/simulation/submodules/altera_onchip_flash_avmm_data_controller.v Line: 1175
# ** Warning: (vsim-3722) C:/MAX10_work/max10_flash/simulation/submodules/altera_onchip_flash_avmm_data_controller.v(1175): [TFMPC] - Missing connection for port 'shiftin'.
# ** Warning: (vsim-3722) C:/MAX10_work/max10_flash/simulation/submodules/altera_onchip_flash_avmm_data_controller.v(1175): [TFMPC] - Missing connection for port 'aset'.
# ** Warning: (vsim-3722) C:/MAX10_work/max10_flash/simulation/submodules/altera_onchip_flash_avmm_data_controller.v(1175): [TFMPC] - Missing connection for port 'sclr'.
# ** Warning: (vsim-3722) C:/MAX10_work/max10_flash/simulation/submodules/altera_onchip_flash_avmm_data_controller.v(1175): [TFMPC] - Missing connection for port 'sset'.
# ** Warning: (vsim-3722) C:/MAX10_work/max10_flash/simulation/submodules/altera_onchip_flash_avmm_data_controller.v(1175): [TFMPC] - Missing connection for port 'q'.
# ** Warning: (vsim-2685) [TFMPC] - Too few port connections for 'altera_onchip_flash_block'. Expected 18, found 17.
# Time: 0 ps Iteration: 0 Instance: /testbench/UUT/flash/onchip_flash_0/altera_onchip_flash_block File: C:/MAX10_work/max10_flash/simulation/submodules/altera_onchip_flash.v Line: 302
# ** Warning: (vsim-3722) C:/MAX10_work/max10_flash/simulation/submodules/altera_onchip_flash.v(302): [TFMPC] - Missing connection for port 'bgpbusy'.
# ** Warning: (vsim-2685) [TFMPC] - Too few port connections for '<protected>'. Expected <protected>, found <protected>.
# Time: 0 ps Iteration: 0 Protected: /testbench/UUT/flash/onchip_flash_0/altera_onchip_flash_block/inst/<protected>/<protected>/<protected>/<protected>/<protected> File: $MODEL_TECH/../altera/verilog/src/mentor/fiftyfivenm_atoms_ncrypt.v Line: 38
# ** Warning: (vsim-3722) <protected>(<protected>): [TFMPC] - Missing connection for port '<protected>'.
# ** Warning: (vsim-3722) <protected>(<protected>): [TFMPC] - Missing connection for port '<protected>'.testbench.UUT.flash.onchip_flash_0.altera_onchip_flash_block.inst.<protected>.<protected>.<protected>.<protected>.<protected>.<protected>: 1.25ns: WARNING: DIN shows unknown state!
