Cannot get Cyclone 10 GX HDMI RX to lock
- 5 years ago
Hi Neil,
We suspect HDMI Rx failure encountered at your site is expected because you removed NIOS II design block which also function to perform CDR refclk switching from CDR refclk0 to CDR refclk1.
- Your modified HDMI Rx design is now stuck with wrong (CDR refclk0) instead of using correct TMDS clock (CDR refclk1).
In short, I believe you can follow below guideline that I drafted
Guideline for modification to HDMI Rx only design should be like below :
- Option A : for customer that required quick XCVR power up calibration
- Remove everything else but keep (HDMI Rx top, NIOS II design and also the design code with comment "// Workaround for long power-up calibration issue")
- Option B : for customer that doesn’t need “quick XCVR power up calibration” requirement
- Remove everything else including NIOS II design, just keep HDMI Rx top only
- Modify gxb_rx NativePHY IP to change default CDR refclk to 1 (refer to attached pic)
- regenerate gxb_rx IP and recompile HDMI design again
I am sorry Malaysia Cocid-19 situation is pretty bad where we are not allow to go back office until early Dec. I need to rely on you for now to help verify the HDMI design on hardware.
Thanks for your understanding.
dlim
Hi Neil,
dlim
- NWein5 years ago
Thanks. We do not require the quick power up calibration and definitely don't want the NIOS, so I will attempt option B. I am hopeful.
COVID-19 situation is terrible here, but I have all this stuff in my house right now so I can keep going.
- NWein5 years ago
It looks like changing refclk to 1 was the secret sauce. I now have full RX-only functionality on the dev board, across all resolutions.
The only slight issue I'm seeing is that the first time it connects, at 4K60, something is not quite stable. If I change resolutions and resync, everything after that is solid. This is something I'll be looking into but doesn't particularly worry me at the moment.
I am now in the process of trying to transfer everything onto my own hardware. It is already working better than before, but not fully. Translating all the constraints will take a bit of time.
Thanks for your persistence on this issue!
