Cannot get Cyclone 10 GX HDMI RX to lock
- 5 years ago
Hi Neil,
We suspect HDMI Rx failure encountered at your site is expected because you removed NIOS II design block which also function to perform CDR refclk switching from CDR refclk0 to CDR refclk1.
- Your modified HDMI Rx design is now stuck with wrong (CDR refclk0) instead of using correct TMDS clock (CDR refclk1).
In short, I believe you can follow below guideline that I drafted
Guideline for modification to HDMI Rx only design should be like below :
- Option A : for customer that required quick XCVR power up calibration
- Remove everything else but keep (HDMI Rx top, NIOS II design and also the design code with comment "// Workaround for long power-up calibration issue")
- Option B : for customer that doesn’t need “quick XCVR power up calibration” requirement
- Remove everything else including NIOS II design, just keep HDMI Rx top only
- Modify gxb_rx NativePHY IP to change default CDR refclk to 1 (refer to attached pic)
- regenerate gxb_rx IP and recompile HDMI design again
I am sorry Malaysia Cocid-19 situation is pretty bad where we are not allow to go back office until early Dec. I need to rely on you for now to help verify the HDMI design on hardware.
Thanks for your understanding.
dlim
Hi Neil,
Great. We are making good progress here. We solved the tough part and now marching towards more easier part I guess.
I am not too sure about the “unlicensed HDMI IP core in evaluation mode” either. I will try ask around to see if I can find out anything.
- Btw, how do you get the license in the first place ? Is there any Intel FPGA support FAE that you can consult to clarify further ?
Regarding software setup
- I am using Quartus Linux version. May I know are you using Quartus Linux or Quartus Windows version ?
- Another thing that I think can help you out is let me create step by step screenshot on how I generated HDMI example design. Then you can cross check to see are you following the same procedure here.
dlim
- NWein5 years ago
1) We simply have not purchase the core yet, since we're still debugging a handful of units that are always running tethered. Once we have a larger number of devices to distribute to more software developers and/or testers, we'll buy the core. However, if we can determine that for some crazy reason the unlicensed mode *is* causing our problems, we can purchase the core (through Arrow). But according to all available information it *shouldn't* be the problem.
2) I'm running QPP 20.2 under Windows 10
3) I've been told that, for now, this forum is to be my primary source of support.
Neil
- Deshi_Intel5 years ago
Attached is C10 GX HDMI design example generation guideline
