Cannot get Cyclone 10 GX HDMI RX to lock
- 5 years ago
Hi Neil,
We suspect HDMI Rx failure encountered at your site is expected because you removed NIOS II design block which also function to perform CDR refclk switching from CDR refclk0 to CDR refclk1.
- Your modified HDMI Rx design is now stuck with wrong (CDR refclk0) instead of using correct TMDS clock (CDR refclk1).
In short, I believe you can follow below guideline that I drafted
Guideline for modification to HDMI Rx only design should be like below :
- Option A : for customer that required quick XCVR power up calibration
- Remove everything else but keep (HDMI Rx top, NIOS II design and also the design code with comment "// Workaround for long power-up calibration issue")
- Option B : for customer that doesn’t need “quick XCVR power up calibration” requirement
- Remove everything else including NIOS II design, just keep HDMI Rx top only
- Modify gxb_rx NativePHY IP to change default CDR refclk to 1 (refer to attached pic)
- regenerate gxb_rx IP and recompile HDMI design again
I am sorry Malaysia Cocid-19 situation is pretty bad where we are not allow to go back office until early Dec. I need to rely on you for now to help verify the HDMI design on hardware.
Thanks for your understanding.
dlim
HI Neil,
Attached is the test result screen shot from Intel HDMI validation team verifying the v20.2 HDMI example design that I shared with them.
This is expected test result for (deep colour mode = off) setting.
- 8bpc test result is passing while 10bpc and 12 bpc test result are failing
Why not let me share my HDMI example design sof file for you to try out on your C10 GX dev kit board.
dlim
Thanks. As I communicated to you via PM, the SOF file you provided me works correctly, confirming my dev board setup.
Given that the hardware is verified, that leaves my software setup or operator error. I'm not sure what I could do differently at this point. I generated the example design and compiled it in-place, with no modifications.
- NWein5 years ago
There is one difference between my SW setup and yours... I'm at the moment using the unlicensed HDMI core in evaluation mode. As I understand, it should operate with full functionality while I'm tethered, but it is possible that that could be affecting operation somehow?
