Cannot get Cyclone 10 GX HDMI RX to lock
- 5 years ago
Hi Neil,
We suspect HDMI Rx failure encountered at your site is expected because you removed NIOS II design block which also function to perform CDR refclk switching from CDR refclk0 to CDR refclk1.
- Your modified HDMI Rx design is now stuck with wrong (CDR refclk0) instead of using correct TMDS clock (CDR refclk1).
In short, I believe you can follow below guideline that I drafted
Guideline for modification to HDMI Rx only design should be like below :
- Option A : for customer that required quick XCVR power up calibration
- Remove everything else but keep (HDMI Rx top, NIOS II design and also the design code with comment "// Workaround for long power-up calibration issue")
- Option B : for customer that doesn’t need “quick XCVR power up calibration” requirement
- Remove everything else including NIOS II design, just keep HDMI Rx top only
- Modify gxb_rx NativePHY IP to change default CDR refclk to 1 (refer to attached pic)
- regenerate gxb_rx IP and recompile HDMI design again
I am sorry Malaysia Cocid-19 situation is pretty bad where we are not allow to go back office until early Dec. I need to rely on you for now to help verify the HDMI design on hardware.
Thanks for your understanding.
dlim
No worries there, the analyzer (like any HDMI source) obeys the EDID.
It looks like the project behaves just about the same on the dev board as on our own hardware. The STP files attached to the first message represent it well. As before, behavior is different at different resolutions. Most resolutions achieve HDMI sync but it flits in and out. Video sync is never achieved. At some resolutions (e.g., 1024x768x60) HDMI sync is never achieved.
Again, this is essentially the HDMI receiver from the example design, unaltered, with my own code to loop the reconfig management bus output from the RX back to the input (that's in reconfigLoopback file in archive I sent). I'm pretty sure that code is OK but it bears checking.
It is unclear to me where to look for the problem.
