WShep1
Contributor
6 years agoCan you make signal assignments to Signal Tap from the RTL Viewer in Quartus Lite 18.1 as explained in the Signal Tap Getting Started Tutorial?
WShep1
Contributor
6 years agoThanks for your response and assistance. As it turns out, it does work with some signals/elements in the Tech Viewer, but not others. If you click on most signals/elements, the Signal Tap choice is available. However, there are some for which it is not available and that is what confused me the first time that I tried the Tech Viewer.
