WShep1
Contributor
6 years agoCan you make signal assignments to Signal Tap from the RTL Viewer in Quartus Lite 18.1 as explained in the Signal Tap Getting Started Tutorial?
sstrell
6 years agoSorry, this can only be done from the Technology Map Viewer to tap post-fit signals, not the RTL Viewer. This feature is available in all Editions of the software, but I forgot that it was post-fit only. What tutorial are you referring to (URL) that says you can do this in the RTL Viewer?
#iwork4intel
