Likewise
7 years agoCan we use 256 PCIe tags handled in soft-logic?
Hello all, I am reading contradictory information about the support for 256 tags with the PCIe HIP. We are using the HIP with it's ST RX/TX interface (Stratix V and newer), not any of the DMA-MM sof...
Nathan_R_Intel
Contributor
7 years agoHie,
The "Configuration Bypass mode" is required for 128 or 256 tags in only applicable for Arria 10 and Cyclone 10 devices. Refer to link below:
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/ip/2018/why-does-the--number-of-tags-supported--parameter-does-only-show.html
Arria 10 similar to Stratix 10 requires "Application Layer" to validate the completion tags for 256 tags support.
However, Stratix 10 HIP does support 256 tags without requiring application layer to perform completion tag checking.
Nathan
