LHøi0
6 years agoCan the altera_pll version 18.0 be used on Cyclone V without the RREF_TL pin connected?
We are using a 5CEBA2F17C8N, 60 MHz input clock, PLL output clock also 60 MHz, feedback mode is "normal". After an IP upgrade the PLL stopped running. The upgraded PLL IP version was 18.1. Copying al...
S_Healthineers
6 years agoI have the same problem and am working with version 18.1. Now I'm waiting for the new boards where the forgotten pin RREF has been adjusted.
If I understand that correctly, if I use version 18.0, the problem is not there and then I have no problems with the PLL that do not lock.
