Yod1
5 years agoCan not generate example design of HDMI Intel FPGA IP
Hi all,
When I used the Quartus version 20.1 standard to generate the example design, I got the error message like this:
Error: no files matched glob pattern "*" while executing "__altera__safe_glob -directory C:/Users/myaccount/AppData/Local/Temp/alt8800_4565935366385225410.dir/0005_hdmi_0_gen/sv_hdmi2/software/hdmi_demo_bsp..." ("uplevel" body line 1) invoked from within "uplevel 1 [list __altera__safe_glob {*}$args]" (procedure "glob" line 2) invoked from within "glob -directory $src_dir *" (procedure "glob_recursive" line 2) invoked from within "glob_recursive $item [file join $dest_dir $filename] $top_name" (procedure "glob_recursive" line 8) invoked from within "glob_recursive $item [file join $dest_dir $filename] $top_name" (procedure "glob_recursive" line 8) invoked from within "glob_recursive [pwd] {} $ed_name" (procedure "generate_copy_ed" line 40) invoked from within "generate_copy_ed $design_name($family)" (procedure "generate_example" line 11) invoked from within "generate_example hdmi_0_example_design"
I have tried the following, but I still get the error.
https://community.intel.com/t5/FPGA-SoC-And-CPLD-Boards-And/How-can-I-use-the-HDMI-Tx-port-on-Arria-V-GX-Starter-kit/m-p/669841#M13209
How can I solve this problem?
1 Reply
- Deshi_Intel
Kindly provide more info below so that we can help you out further ?
- Which FPGA device family that you are using here ?
- Are you trying to generate HDMI hardware example design or simulation example design ?
- What setting that you configure in HDMI IP ? Pls share screen shot
- Are you using Wins or Linux OS ?
dlim
