11 years agoCan Nios II/e and LPM_divide be used without a license & w/o being tethered to PC?
I am working on a design that uses a nios II/e and the LPM_Divide megafunction using a de0-nano. Can these be used without having to stay tethered to the pc? I've tried reaching out to Altera but t...
11 years agoI think the nios e core is free and shouldnt require being tethered. if you use the f or s core then its time limited. I also think lpm divide is free.
infact after a quick google: Nios II/e "Economy" Altera specifically designed the Nios® II/e "economy" processor cores to use the fewest FPGA logic and memory resources. It is now offered free (for both Nios II Classic and Nios II Gen2 processors), no license required, with Quartus® II software version 9.1 and later. The Nios II/e core has higher performance but is in the same cost class as a typical 8051 architecture, achieving over 30 DMIPS at up to 200 MHz, and using fewer than 700 logic elements (LEs). from https://www.altera.com/products/processors/benefits/nios-ii-processor-cores.html
