HLove
7 years agoCan I use RGMII with the TSE IP core on a Cyclone 10 GX?
Using the IP generator, I have made a TSE IP Core. However, it only seems to give me the option to have MII/GMII, but not RGMII. Is this intentional? Am I able to use RGMII through this IP core at all? I'm using Quartus Pro 19.1.
Many thanks,
- Hi Henry, Unfortunately RGMII is not supported in Cyclone 10 GX due to FPGA architecture limitation as mentioned in below KDB link. https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/ip/2017/does-the-triple-speed-ethernet-ip-core-support-rgmii-mode-in-a10.html The option is to use either GMII or SGMII. Thanks. REgards, dlim
- Deshi_Intel
Hi Henry, Unfortunately RGMII is not supported in Cyclone 10 GX due to FPGA architecture limitation as mentioned in below KDB link. https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/ip/2017/does-the-triple-speed-ethernet-ip-core-support-rgmii-mode-in-a10.html The option is to use either GMII or SGMII. Thanks. REgards, dlim - HLove
Hi dlim,
Thank you for confirming.
Henry
