NYao
6 years agoCan HDMI2.1 be implemented using Arria 10 -3 grade FPGA?
Dear, I know we have HDMI2.1 demo using A10 development kit, can i using this IP on -3 grade devices? like 10AX027H4F34I3G?
- 6 years ago
Hi, It is recommended to use Arria 10 FPGA device with speed grade 2 or faster. You might facing timing issue if you use Speed grade -3
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_hdmi.pdf#page=15
BoonT_Intel
6 years agoIt is recommended to follow the table. Even you able to see the timing passing. But there still a risk marginal issue on it (even the lower speed grade -3 pass timing). Also, the internal hardware validation is carry on based on the recommended table.
