GabrieleCoppolino
6 years agoC10GX and TSE with GXB transceivers
Hi all, I'm having some problems configuring the Triple Speed Ethernet core, working at 1Gbps, with a custom board with 6 transceiver channels (for now I'm trying to use 2 of them) connected to a Cy...
CheepinC_altera
6 years agoHi,
As I understand it, you are encountering some issue when using TSE with XCVR in C10GX devices. There seems to be no issue when you are using Native PHY only and performing loopback. However, when you hook up the TSE, you observe issue. For your information, I am currently engaging our TSE expert to provide further assistance. Thanks for your patience.
GabrieleCoppolino
6 years agoYes, exactly. Here attached the PHY configuration, where among two transceiver channels I shortcircuited rx_parallel_data and tx_parallel_data, and rx_datak with tx_datak.
