C10 GX FPll Reconfig
- 6 years ago
Hi ,
For confidentiality purpose the communication is taken to private conversation
Hi Johson ,
Can you please help me to understand further on the issue , what is the issue you are facing exactly , is the reference design is not working .
Or , you could not able to change the setting on the fpll of the reference design.
The reason for the ask , is that i can contact the designer owner to solve the issue
- JLee256 years ago
Contributor
Hi Rahul,
My problem is I need to dynamically change the output settings for different resolutions.
That meas the fPLL output clock rate must following my settings. e.g. 1080p60, 1080p30, 2160p30.....
Therefore I need the know how to do that..
Unfortunately, I did not find any document reference to the fPLL register definitions nor the user guide..
BRs,
Johnson
