XQSHEN
4 years agoburst read and write DDR2 using altmemphy
1) Need forum admin to help, I can not post any reply on below topic even use different browser.
2) answer to this topic:
I set memory burst length = 8, and use half rate.
Can I set loca...
AdzimZM_Altera
4 years agoI don't have the exact reason on why you cannot set a higher local_size but I think it's the limitation on the controller side.
So you have to follow the document for your configuration.
