built msim_setup.tcl in ip-make-simscrpt. Need procedure to get PLLs in "work" directory. Getting "failed to run ip-make-simscript" invoking modelsim from quartus.
- AnandRaj_S_Intel
Can you please launch modelsim directly and try(instead of invoking from quartus ).
I have to run -> ip-make-simscript --spd=<directory>/ pll1.spd --output-directory=<directory> --compile-to-work --use-relative-paths from command prompt to generate msim_setup.tcl
and follow the steps given in msim_setup.tcl for simulation.
- set QSYS_SIMDIR <directory>/pllsim
- source $QSYS_SIMDIR/mentor/msim_setup.tcl
Which loads the design without any error.
Reference
https://www.intel.com/content/www/us/en/programmable/documentation/aym1499789502823.html
Anand
- LCard2
Hi, Msim_setup.tcl run, followed instructions. Is …<directory> necessarily directory with top level entity? Do the ip generated files I have (IPpll.v, IPpll_inst.v, and IPpll_0002.v) have to be in project folder or just IPpll.qip? Without invoking ModelSim from Quartus, how doe a woek directory get populated? Len- AnandRaj_S_Intel
Yes,Refer transcript.
yes, i have all IPpll.v, IPpll_0002.v & IPpll.qip.
How doe a woek directory get populated?
Script will take care.
Attached the transcript & images.
Anand
