11 years agoBFM Read from On Chip RAM
I followed D. W. Hawkins ([email protected]) tutorial on JTAG-to-Avalon-MM. There is a task in the tutorial that reads a slave address using the BFM master. The slave is onchip_ram. The problem is...
11 years ago --- Quote Start --- I just ran the simulation on ModelSim and traced the waitrequest=0 and readdatavalid=1 signals generated by the Avalon translator connected to this on-chip RAM. The readdatavalid is produced properly the next clock cycle when data is ready to read but the BFM master still reads the previous clock cycle --- Quote End --- Try tracing at the BFM interface, i.e., your Qsys design will have BFM<->fabric<->Slave. Since the fabric to slave interface does not have a waitrequest and readdatavalid, try probing at the BFM side. This might be what you just did, but it was not clear in your description ... Cheers, Dave
