TwoBit
6 years agoBFM MM-Master Help for custom IP
Hi, I have made a module that includes two FIFOs (taken from the IP catalog and set up by selecting options from the Wizard box.) There are a few registers made to be used for testing and in place...
sstrell
6 years agoLike I said, a design with a BFM is not synthesizable so you can't compile it. It is for simulation only. The testbench and everything else generated by Platform Designer when you do "Generate Testbench" is for the simulation tool, not Quartus.
#iwork4intel
