Avalon Streaming Dual Clock FIFO
- 1 year ago
Understood that. Could you try to use the simple adapter ST handshake clock crosser under the bridges and adapters section? I think you're connecting it correctly previously. Instead of using dual clock fifo under on-chip memory section, as it's embedded peripheral I'm not sure is there anything needs to take note when using it.
Regarding why booting slow when using 200mhz, you need to open a new thread target pcie to get the related pcie expert helps.
Sheng
Could you try test case below:
Test1: Main clock(50mhz) -> pll (50mhz) -> all peripherals
Test2: Main clock(50mhz) -> pll (100/200mhz) -> all peripherals
Are both tests pass?
Main clock(50mhz) -> pll (200mhz) -> all peripherals did work! Thanks.
However - the system boot is now much much slower. Maybe 10x slower.
Do you know why this could be??
Many thanks.
