Avalon-ST Mux Not Round-Robining
- 7 years ago
My setup for this was two Avalon-ST interfaces wishing to use a single TSEC for egress from my FPGA. One of the streams was 32b@100MHz originating within QSYS, the other 8b@125MHz from external data plane. What I was originally seeing in QSYS with the Avalon-ST MUX set up to operate at 32b@100MHz was only my traffic from QSYS passing through the mux. When data arrived at the mux from my external data plane (via a width and clock adapter) the valid signal was choppy and I originally thought this might be causing issues even though it was within the avalon spec.
To solve the problem I changed the setup of my MUX to be 8b@125MHz (this required adding in an extra clock interface for my QSYS block). I used a DC FIFO to cross the clock domain within QSYS, and then let the width adaption take care of itself and fed this interface into port 0 of the MUX. I was then simply able to import my data plane traffic into QSYS to take advantage of the MUX. The output of the MUX was exported out of QSYS and into my ethernet wrapper block. This solved the issues I was having that the MUX would not detect packets arriving at both interfaces.
