GDagi1
6 years agoAvalon-MM slave shows constant high reg_busy signal (TSE IP).
Hi all, I am currently using the Triple-Speed Ethernet IP and have read in order to properly use it I need to first configure the register space. In order to do that, believe I need to use the MAC C...
Deshi_Intel
6 years agoHI,
I am closing this case as well as per my feedback in another forum case while we moved all debug discussion into Andy's case.
dlim
MRigh4
6 years agoHello, I have the same problem, could you post the link where the discussion continued?
Thank you,
Marco
