GDagi1
6 years agoAvalon-MM slave shows constant high reg_busy signal (TSE IP).
Hi all, I am currently using the Triple-Speed Ethernet IP and have read in order to properly use it I need to first configure the register space. In order to do that, believe I need to use the MAC C...
Deshi_Intel
6 years agoHI,
I worry whole TSE IP is still stuck. That could explained why it can't function properly.
I am not even sure whether it's out from reset properly or not.
You may want to checkout following first
- Use the example design to run one time sim to get an idea of expected signal behaviour
- then back to your own design, check the TSE clocking, reset and also your reg_config_done. Let the sim run longer to see if there is any difference. You can also compare the sim run time with working example design as reference.
dlim
