sadad
7 years agoAvalon Interconnect Dynamic Bus Sizing and Bursts
Hello! My Avalon-MM master has 32bit data width and is bursting capable. Now i connect an Avalon-MM slave with 8bit data width which is also bursting capable. Will a 32bit read or write access to ...
JohnT_Altera
7 years agoHi,
Yes, the Avalon adapter will performed a single burst of 4 x 8bit since the slave is able to support. A non 4 non bursting transfer 8bit will only happen when the slave is not able to support it
BInos
7 years agoMy tests showed only partly this result:
Further discussion: https://forums.intel.com/s/question/0D50P00004OQKyLSAX/avalon-interconnect-dynamic-bus-sizing-and-bursts
