mifa
7 years agoAvalaon MM BFM read problem
Hi, I am trying to read from my custom IP, but i have the problem that the BFM Master does not see any kind of acknowledge by the slave. My IP combines multiple interfaces with an Avalon Pipeline b...
mifa
7 years agoIt works if I manually instantiate the BFM in the top-level file and not in the QSYS with the IP. This will prevent that QSYS inserts an interconnect between them which does more bad than good.
Anyways, I would like understand the problem because it would be more confortable to use the BFM in qsys.
There must be a wrong or missing information anywhere, which causes the interconnect to build something wrong between the BFM and the custom IP. Any suggestions? Is there a parameter which tells the pipeline bridge to work without readdatavalid?
