zeahr
7 years agoASMI Parallel II elaboration error
Hi, I tried to simulate the Quartus generated testbench of ASMI Parallel II ip core but there is an error during elaboration. I am using Modelsim DE 10.6a running on Linux, and I am using Quartus P...
- 7 years ago
Hi Zeahr,
You can try use the MT25QL256 (Micron's QSPI flash) simulation model as we are going to support MT25Q flash due to the EPCQ256 EOL announcement here. There are no EPCQ simulation model files available.
Nooraini
AnandRaj_S_Intel
7 years agoHi Zeahr,
Have you enabled the enable_sim parameter?
Error is due to Version & environment comparability
To avoid error by
- You have to use same environment from project creation and simulation.
- Appropriate modelsim to be used with respect to Quartus version.
I was able to simulate successfully using Quartus 18.1 Std & Modelsim SE 10.5b in windows 10 environment.
Attached the transcript and image for reference.
Anand Raj Shankar
