zeahr
7 years agoASMI Parallel II elaboration error
Hi, I tried to simulate the Quartus generated testbench of ASMI Parallel II ip core but there is an error during elaboration. I am using Modelsim DE 10.6a running on Linux, and I am using Quartus P...
- 7 years ago
Hi Zeahr,
You can try use the MT25QL256 (Micron's QSPI flash) simulation model as we are going to support MT25Q flash due to the EPCQ256 EOL announcement here. There are no EPCQ simulation model files available.
Nooraini
zeahr
7 years agoHi Nooraini,
Thank you for your reply.
Yes, I did turned on the "Enable flash simulation model" option.
Where can I download the EPCQ256 simulation model? I cannot find it in Intel website.
Should I use a third party model (i.e. Micron's Serial flash)? if yes, what device is compatible to EPCQ256?
Thank you.
Zeahr
