SKuma36
7 years agoArria10 PCIe Hard IP link bring up issue
Hi, We are trying to bring-up PCIe (Gen1 x1) interface using Arria 10 PCIe Hard IP on Intel's Arria10 Signal Integrity development board. The design is found to be working in simulation, but on the...
SengKok_L_Intel
7 years agoHi Sir,
To confirm your design is working fine for the external loopback, you can change the pin assignment to the channel that using 2.4 SMA connectors. If this passed, then you need to double check on your hardware setup. And maybe using a scope to confirm if there is a signal sending out from TX.
Regards -SK
