TerryU
7 years agoArria 10 Transceiver PHY parameters for CDR
Hi experts, I have reference lock issue on high speed interface mode. Then, I would need CDR-PLL related values, actually I have found some improvement with modification. However the following param...
TerryU
7 years agoHi Chee-san,
I attach a file including two screen shots of Signal Tap. The rx_is_lockedtoref is rise up immediately after releasing rx_analogreset in Pass board. However the rx_is _lockedtoref always stays Low after rx_analogreset. I have done a plenty of analysis, reset timing, clock waveform check etc. , but there was no solution without those value's modification so far.
TerryU/Tetsuya
