TerryU
8 years agoArria 10 Receiver-Transceiver PHY calibration
Hi experts, I use Arria 10 device and configure SAS (Serial Attached SCSI) interface. When I assembled many boards, and then around 10% boards failed with SAS link error. In my analysis on Signal T...
CheepinC_altera
8 years agoHi TerryU,
Yes you are right. If you are performing rate change involving CDR, you would need to set the rate switch register following the user guide. Thank you.
Chee Pin
