Arria 10 Receiver-Transceiver PHY calibration
Hi TerryU,
As I understand it, you have some inquiries related to A10 XCVR RX calibration.
Specific to your inquiry of "What is the actual function of calibration and how does it effect to receiver-phy? I guess that it would effect to PLL optimization. Is it correct?", for your information, after you perform a rate change to the XCVR, a recalibration is required to fine tune the internal parameters of the TX PLL, RX PMA and TX PMA to ensure that they are optimal at your new data rates. This is also to ensure that XCVR blocks will operate as expected at the new data rates. You may refer to the A10 XCVR PHY user guide -> "Figure 284. Recalibration Sequence when the Transceiver Reference Clock or Data Rate Changes" for the blocks that required to be recalibrated after a rate change.
Just would like to check with you when you switch to 3Gbps and perform user recalibration, the RX CDR still unable to achieve lock to data? Or unable to achieve lock to reference as well?
Chee Pin
- xytech7 years ago
Contributor
Hi Chee, @cheepinc_Intel
Your answer helps. Recently I am really struggling with this Calibration thing. From your words, "recalibration is required to fine tune the internal parameters of the TX PLL, RX PMA and TX PMA to ensure that they are optimal at your new data rates. This is also to ensure that XCVR blocks will operate as expected at the new data rates", can I say that if FPGA is not successfully calibrated / re-calibrated, XCVRs can still run, but may with lower performance than it should be?
If you are convenient, would you like to take a look a t this thread , some further description on my questions about A10 GX device calibration.
https://forums.intel.com/s/question/0D50P00004Gf0dgSAB/what-would-happen-if-transceiver-calibration-fails
Thanks, and happy weekend.
