Arria 10 PCIe hard IP
We read about soft reset controller on arria v through the por reset. All the ports for arria 10 show the disabling option???
Post:
For Arria V device, the mapping of nPERST is as below:
- nPERSTL0 --> bottom Hard IP of pin_perst - nPERSTL1 --> top Hard IP of pin_perst In your case, try workaround it by changing to use Soft Reset Controller. Using Soft Reset Controller doesn't required the connection to pin nPERSTL0. Tie pin_perst to 1 at top level file and nPERSTL0 can be left unconnected at pin assignment. Steps to switch to soft reset controller in Qsys: 1) Edit the .qsys file 2) Search for the string 'force_src' 3) Set parameter force_src to 1: <parameter name="force_hrc" value=0" /> <parameter name="force_src" value=1" /> 4) Save the changes to the .qsys file and regenerate the Qsys system. 5) Use npor input to reset the core and application logic.
Translate
