Arria 10 PCIe Gen3x8 DMA(AN 829 ) - Linux Driver Error " Couldn't open the device"
- 5 years ago
Thank for your following up on this issue, SK.
Our issue got resolved, on setting the base class code (upper byte at offset 0Bh in the PCIe configuration space) to 0xFF (Device does not fit any defined class). We did not have to change our host device or OS.
We were able to successfully run the Linux DMA software as mentioned in "AN 829: PCI Express Avalon -MM DMA Reference Design" document.
Sachin
After reboot, do you able to see the FPGA PCIe is enumerated?
What is the output if you run the commands below?
lspci -nn | grep 1172
lspci -s 5:01.0 -vvv (assuming the BDF is 5.01.0).
Besides, you may try to type "make" compile the driver and then run it again.
- sachin_blr5 years ago
Thank you for the response, SK
Following is the output of running the commands that you mentioned.
root@grljetson-desktop:/home/grl-jetson/FPGA_PCIe_driver/AN829_driver# lspci -nn | grep 1172
0005:01:00.0 Non-VGA unclassified device [0000]: Altera Corporation Device [1172:e093] (rev 01)root@grljetson-desktop:/home/grl-jetson/FPGA_PCIe_driver/AN829_driver# lspci -s 5:01:0 -vvv
0005:01:00.0 Non-VGA unclassified device: Altera Corporation Device e093 (rev 01)
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 0
Region 0: Memory at <unassigned> (64-bit, prefetchable) [disabled] [size=512]
Region 2: Memory at <unassigned> (64-bit, prefetchable) [disabled] [size=512M]
Capabilities: [50] MSI: Enable- Count=1/4 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [78] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [80] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 0.000W
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 256 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #1, Speed 8GT/s, Width x8, ASPM not supported, Exit Latency L0s <4us, L1 <1us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 8GT/s, Width x8, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Not Supported, TimeoutDis+, LTR-, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+, EqualizationPhase1+
EqualizationPhase2+, EqualizationPhase3+, LinkEqualizationRequest-
Capabilities: [100 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed- WRR32- WRR64- WRR128-
Ctrl: ArbSelect=Fixed
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
Status: NegoPending- InProgress-
Capabilities: [200 v1] Vendor Specific Information: ID=1172 Rev=0 Len=044 <?>
Capabilities: [300 v1] #19
Capabilities: [800 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-Also, I compiled the driver again(using "make") and ran it. Still getting the same output of "Couldn't open the device." as before
Following are the commands that were used to compile and run (as root user):
- make EXTRA_CFLAGS=-DARRIA10
- ./altera_dma_load
- ./run
Sachin
