Arria 10 PCIe Gen3x8 DMA(AN 829 ) - Linux Driver Error " Couldn't open the device"
- 5 years ago
Thank for your following up on this issue, SK.
Our issue got resolved, on setting the base class code (upper byte at offset 0Bh in the PCIe configuration space) to 0xFF (Device does not fit any defined class). We did not have to change our host device or OS.
We were able to successfully run the Linux DMA software as mentioned in "AN 829: PCI Express Avalon -MM DMA Reference Design" document.
Sachin
Did you use the root (or su) to “make” and “install” the driver?
After programming the SOF, did you restart the host to ensure the PCIe link is enumerated?
Regards -SK
- sachin_blr5 years ago
Hi SK,
Thank you for your response.
I had used "sudo" when running install.
Further, the host was restarted after programming the SOF.
We are still facing the issues mentioned above.
Sachin
