HTong1
7 years agoArria 10 partial reconfiguration thru JTAG debug mode time out. No way to program the partial reconfiguration .rbf file. Please help!
There are two Arria 10 devices in the JTAG chain. The partial reconfiguration IP has the JTAG debug mode enabled. Programming .sof succeeded, but when programming the .rbf file, the Quartus Pro 18.1 ...
HTong1
7 years agoHi John,
It is not fully working by lowering TCK to 6MHz. It can now program the persona's .rbf successfully but it still fails with the same PR_DONE problem when programming the base's .rbf file. As you know, when compiling the base, Quartus also generates a .rbf file for the PR region, similar to the .rbf file generated when compiling the project revision for PR persona. I will try to make another project revision for PR the same as the base to see whether that PR's .rbf can work, and if it does, it can be a work around. But it is a concern that the PR feature may work or not work unpredictably since the base's .rbf is supposed to work.
