Arria 10 can't read from flash via Generic Serial Flash Interface
We have an Arria 10 FPGA connected to a Micron MT25QU256 flash. The FPGA is able to obtain its program from the flash and configure correctly on power-up. We are trying to use the Generic Serial Flash Interface IP to perform an in-system upgrade of the contents of the flash. We have found that we can perform write operations successfully through the GSFI, but read operations do not fully work.
We probed the signals in the bus between the FPGA and the flash and found that the "read device ID" operation is resulting in the flash responding with the correct data on the serial bus (signal DQ1), but when we query the GSFI via the "flash command read data" register, we get all zeroes back. The same is true when we read the status register or the flag status register from the flash device.
Is there some setup we need to do in order to get the GSFI to recognize and properly save the serial data returned from the flash? I can provide more information about our setup and the operations we are performing as needed. Thank you.
Hi John,
1) We are using the GSFI, but gsfa_asmi_access_granted_reg is a register in the Serial Flash Loader.
2) Yes, that is correct, we wanted to start out by seeing the device ID read work correctly before moving on to reading and writing the flash memory.
We have the baud rate divisor set to 0x10 and we have seen the SPI pins behave as expected.
We were able to get everything to work once we removed the Serial Flash Loader from our design, leaving the GSFI directly connected to the SPI interface. I don't think we will need any further assistance; thank you for your help.
Frank
- JohnT_Altera
Could you provide me the step that you used to read the data and what is the setting used in the GSFI CSR Register?
- FZOVK
Hi John,
Thanks for your quick response. Our process for attempting to read the flash device ID is as follows:
1) Set bit 0 of the "gsfa_asmi_access_granted_reg" register to 0 in order to give the GSFA module access to the flash.
2) Write 0x0000489F to the Flash Command Setting Register (register offset 0x7).
3) Write 0x00000001 to the Flash Command Control Register (register offset 0x8).
4) Read the Flash Command Read Data 0 Register (register offset 0xC).
We are getting all zeroes from that read operation at the end, even though we can see (by probing the flash data output line) that the flash is responding properly with the device ID. Also, in case this is relevant, we have connected the following pins between the Serial Flash Loader and the GSFI: atom_ports_dataout, atom_ports_dataoe, atom_ports_datain, atom_ports_dclk, atom_ports_ncs, atom_ports_oe.
- JohnT_Altera
May I know if you are refering to GSFI module? I do not observed any gsfa_asmi_access_granted_reg.
From the setting used, you are reading the ID of the flash.
May I know what is the Baud rate Divisor used? Have you try to measure the SPI pin?
- FZOVK
Hi John,
Frank
- JohnT_Altera
Could you try to remove the Serial Flash Loader from your design? I am afraid that this is causing the issue.
- FZOVK
Yes, we have removed the Serial Flash Loader and everything is working now. Thank you for your help.
Frank
- JohnT_Altera
Glad to be able to help you resolved the issue.
