KCMurphy
4 years agoApparent bug in LPDDR3 simulation (altera_emif:19.2.0) Arria 10
During a long burst read from a (simulated) Micron LPDDR3 memory, the simulation of the Intel Arria 10 hard controller (quarter-rate) eventually drops a 32-bit word (it delivers xxx's for that portio...
- 4 years ago
Hi KCMurphy,
The emif_usr_clk is around 199MHz and that is in the acceptable range.
The ref_clk is still at the 200MHz.
KCMurphy
4 years agoExcept that it does not proceed normally, as I have documented.
First, answer this: after calibration, what period or frequency do you see on emif_usr_clk ?
This is the quarter-rate timing to the user logic and is supposed to be exactly 1/4 of the 800MHz DDR bus clock.
