XQSHEN
6 years agoAny well to reduce ddr2 Uniphy resource usage
It's too huge resource used by DDR2 UNIPHY IP.
Is there any special setting I can use to reduce it?
- sstrell
Which device family/device are you using? Is your concern power? Lack of available resources to fit your design?
- yoichiK_altera
Contributor
Hi
In the Controller settings tab there is Efficiency parameter and there is some option could reduce the resource.
1. lower the command Queue Look-ahead depth.
2. disable reordering option.
Just be aware the those option may make the controller to be less efficient.
