JET60200
Contributor
5 years agoAN829 - PCIe BAR[2] to read/write FPGA-EMIF-DDR4 over 1GB area
hello ,
[ Scenario] We can run AN829 PCIE driver on Arria10 EVM Board.
In the FPGA design example, [pcie_a10_hip] -> [rxm_bar2] can read/write to [ FPGA Emif -> ctrl_amm Slave Node] where we h...
- 5 years ago
I forgot to explain further. In AN829, DDR4 is connected to PCIe DMA port which means DDR4 can only be accessed via DMA control only.
That's why I suggested you to switch to use PCIe IP without enabling the DMA logic insides the IP. Then user can connect PCIe IP directly to memory (like DDR4) and access it.
dlim
Deshi_Intel
5 years agoI forgot to explain further. In AN829, DDR4 is connected to PCIe DMA port which means DDR4 can only be accessed via DMA control only.
dlim
- JET602005 years ago
Contributor
thanks @deshi, understand it. Appreciate your explaination
