HungLam
7 years agoAN829 - PCIE AVMM DMA for external memory - Failed when change from DDR4 to DDR3 protocol
Hi, I refered to AN829 to make the change of EMIF from DDR4 to DDR3. I have adapted the same. And finally, there are several errors, but I am not able to locate where to fix them. "Error(19179): ...
BoonT_Intel
7 years agoGlad to know it is solve now. Yes, the pin for DDR4 and DDR3 is incompatible. You need some modification to the RTL when migrate the IP protocol.
Cheers!
