HungLam
7 years agoAN829 - PCIE AVMM DMA for external memory - Failed when change from DDR4 to DDR3 protocol
Hi, I refered to AN829 to make the change of EMIF from DDR4 to DDR3. I have adapted the same. And finally, there are several errors, but I am not able to locate where to fix them. "Error(19179): ...
HungLam
7 years agoThanks a lot for your answer. I reviewed RTL, but could not figure out the issue, as core.data1[5] is not floating. But I was able to fix it, by checking EMIF interface again, then found some pin was only for DDR4, not DDR3. After removing them, I passed these errors.
