Ftiglius
7 years agoAN744 Arria10 - IEEE1588 Design
Hi to everyone! I ported AN744 design on my Arria10 PCB, with 2 GX channels. It runs fine: closing SFP+ plugs with cross fibre cables, I perform 1588 test, by TCL command. it finish test succesfull...
Ftiglius
7 years agoThnaks! So, probably should be better to redesign own application... (!). I'm attemp to understand AN744. IEEE1588 is applied directly to ToDs: no physical clock modification are made. On this design, there is one Master Tod, and it seems distribute own sync directly to both channels 0,1. Reading about IEEE1588, an Ordinary Clock Master shold give it's syncro to Ordinary Slave via Ethernet , sending PTP messages with related timestamps, but this design seems concepted differently.... There is any possibility to obtain more infos? Thanks again for any support!
