ALTPLL Error: Clock Input port of PLL must be driven by non-inverted input pin or another PLL.
- 7 years ago
Hello, Sorry for delay , I caught into another stuff,
Today morning i get chance to look at your design files , Here is changes i did which made it work
i) Add wire clk_200MHz (which is missing in your top module )
ii) removed th /*synthesis keep */ in clk_int. After these changes it is working for me.
One more thing i noticed is , LVDS IP is opted for internal clock and input of the clock is feed from PLL. iam not sure why ..but i can say it is going to take more PLL resources
Let me know if you have any question /concern ?
Thank you ,
Sree
Thanks Sree that helped. I don't know why but it looks like optimization can't be skipped for ALTPLL IP core.
And yes the LVDS IP core is also using PLL. In fact if LVDS IP core is configured to use internal clock it uses all available PLL resources instead of using only one output of the PLL. Would like to know why this happens.
