ALTPLL Error: Clock Input port of PLL must be driven by non-inverted input pin or another PLL.
- 7 years ago
Hello, Sorry for delay , I caught into another stuff,
Today morning i get chance to look at your design files , Here is changes i did which made it work
i) Add wire clk_200MHz (which is missing in your top module )
ii) removed th /*synthesis keep */ in clk_int. After these changes it is working for me.
One more thing i noticed is , LVDS IP is opted for internal clock and input of the clock is feed from PLL. iam not sure why ..but i can say it is going to take more PLL resources
Let me know if you have any question /concern ?
Thank you ,
Sree
I first got this error even before I had done any pin assignment. After that I tried assigning CLK2n Pin # 89 (yes that is an inverted pin), CLK2p Pin # 88, CLK0n Pin # 26, CLK0p Pin # 27 to the single ended clock input, but the error persisted.
Thanks for sharing the KDB solution, I will try it and report any progress here.
