SMS
7 years agoALTPLL Error: Clock Input port of PLL must be driven by non-inverted input pin or another PLL.
Device: Max10 (10M16SAE144I7G) I am trying to use the ALTPLL IP core in my design for frequency synthesis. The clock input of the ALTPLL is directly fed by external oscillator via one of the dedicat...
- 7 years ago
Hello, Sorry for delay , I caught into another stuff,
Today morning i get chance to look at your design files , Here is changes i did which made it work
i) Add wire clk_200MHz (which is missing in your top module )
ii) removed th /*synthesis keep */ in clk_int. After these changes it is working for me.
One more thing i noticed is , LVDS IP is opted for internal clock and input of the clock is feed from PLL. iam not sure why ..but i can say it is going to take more PLL resources
Let me know if you have any question /concern ?
Thank you ,
Sree
SreekumarR_G_Intel
7 years agoHello ,
Can you let me know in which pin exactly clock is connected ?
from the error it is very clear that clock is connected to the inverted pin which is name_N.
If the clock input to the FPGA is single ended it must need to connect to the pin_P (non-inverted ).
Also if you still facing the issue , can you also try below constraint
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd02012010_744.html?_ga=2.211051409.504554538.1557376570-1310395169.1552995784&erpm_id=8221258
Thank you ,
Sree
