SHard2
6 years agoALTLVDS Upgrade Failed
Hi I am attempting to migrate a project created with Quartus v13.0 to v19.1. The 'Upgrade IP Components' wizard has failed at the 'ALTLVDS' component with the following... 'No compatible IP parame...
KennyT_altera
6 years agoThe reason is you have use the quartus version which is too old to have this Upgrade IP component functions. From 13.0 to Q19.1 is a huge gap in the Quartus improvement.
What I suggest is you install Q13.0 and look into the setting, recreate this module in Q19.1 and put back the setting over there.
