ALTFP_MULT is not behaving as per the inputs given
As I understand it, you have some inquiries related to the ALTFP_MULT IP where the output seems to stuck at 0.
To facilitate further debugging, just would like to check with you on the following:
1. Would you mind to share with me the IP .v file so that I can have further understanding of your confuguration?
2. Just would like to check with you if you are observing this issue in Modelsim or hardware? It would be great if you can perform Modelsim simulation to isolate any functional issue prior to hardware testing.
3. For your information, the data input would need to be in floating point format ie the MSB is the sign, the next MSBs are the exponent, and the LSBs are the mantissa. Just to double check with you on the data format.
Chee Pin
- TBaki6 years ago
I think the input i fed to IP was incorrect. I was mot using floating point format ( point 3). Thanks
